А я почем знаю? Может кто подскажет, что это такое?Napic писал(а):оно естеровое Хорошо это или плохо?
Кто какие масла собирается лить в свой NewMPS?
- oleggelo
- Мой автомобиль(и):: НМПС (Intense 5AT, S04, серебро)
Re: Кто какие масла собирается лить в свой NewMPS?
- Napic
- Двигатель:: дизель 4d56
Там свои заморочки.oleggelo писал(а):А я почем знаю? Может кто подскажет, что это такое?Napic писал(а):оно естеровое Хорошо это или плохо?
Наверное приторможу на вэлволин synpoiwer 5w30 надоело просто искать золотую середину. Притормозил после того как увидел это
Коментарии владельца
@Hi, I’m Doug. I’m an expediter contracted on with Bolt Express in Toledo, Ohio. I drive a 1997 Ford E-250 and it now has over 1,100,000 miles on the original motor and original transmission. Both have never been rebuilt. Many parts on my van are still original. I’ve never had the transmission pan off and have never replaced the transmission filter. I’ve used only Valvoline brand of Oil and have used their T-Tech machine for my transmission fluid changes at approx every 50,000 miles. I change my oil approx every 10,000 miles. I have to add a quart of oil every full tank of gas so there is always some new oil in the pan. I just wait for it to go black before changing it. My longest period between oil changes was 55,000 miles a few years back. Is that bad?? I use the regular Oil, no high milage oil. On 7-16-07 I replaced my first muffler and tailpipe, in front of the muffler still original. I was able to get over 500,000 miles on my original serpentine belt before changing it. I kept it as a high milage trophy belt. I had to keep a belt with that many miles on it. Most all my repairs are done by Mytee discount automotive on Holland Sylvania rd in Toledo, Ohio. B&R quick lube in Monroe, Michigan is the oil change place that taught me about all my fluid changes. Big thank you’s go to both of them places.@
Все-таки 1 600 000 км на масле вэлволин это круто. Движок родной и не перебирался.
- G.A.P
- Двигатель:: 3.2 DI-D 4M41
Ты вроде большой дядя, а в сказки веришь, это ж интернет, тут можно написать всё что угодно и видео выложить
- Свят
По поводу Вольволайн....
Норвегия и Швеция эту продукцию оочень уважает. На станциях(настоящих, не то что у нас) Скания и Вольво ГСМ этого производителя продаётся на равне с оригиналом(и кроме Лайна ничего больше!). Обслуживают жидкостями на выбор....
Разговаривал с менеджером станции FFR(Норвежский крупный перевозчик, он-же диллер Volvo)- некоторая продукция, в том числе и масла, превосходит требования многих производителей авто. Скандинавы чуваки грамотные, проверено
С такой головоломкой в выборе масла я решил пологаться на опыт работы других моторов а не заяки и требования каких бы то нибыло производителей. Только пока не опредилился с моторами
Ну вот движок, и движок, одни системы, один смысл и принцип работы, практически одни и теже материалы пар трения,- выбираем самую жёсткую эксплуатацию *другого* мотора и смотрим- работает долго? исправно? холодные пуски? Думаем, определяемся..
Может я и неправ, но лучше верить в успех опираясь на чей то опыт или грабли, чем тупо верить заявкам маслоторговцев....
На форуме писАли о Мобиле Делваке 10W30, масло хорошее вроде, цена тоже
, но вот в -34 завёл Вольву Фашку без Вебасты после 2х суток стояния на таком морозе- давануло маслушко с мотора сурьёзно....
как то так
как то так
+7921 030четыре030 Святослав
ФАНТОМ
Toyota Tundra
ФАНТОМ
Toyota Tundra
- Napic
Свят, Я вообще никому не верю, но раз даже Десептиконы используют вальволин - им безоговорочно поверю и буду впредь только на этом маслеСвят писал(а):По поводу Вольволайн....
black910
- Мой автомобиль(и):: Pajero Sport 3.2
Долго ждалНаверное приторможу на вэлволин synpoiwer 5w30 надоело просто искать золотую середину.
Подбор масла от valvoline
для 4М41
http://www.olyslager-lubricants.nl/valv ... 491493c496
для 4d56 (если правильно подобрал)
кажется наиболее подходящим является SynPower MXL SAE 5W-30
http://www.valvolineeurope.com/english/ ... nformation
Джульбарс
зима - Nokian Nordman SUV 265/65 R17
лето - Cooper Discoverer ST maxx 265/70 r17
- Napic
Нету в магазинах моего города такого и не было. Есть просто обычное. Вроде MXL это с добавлением естеров и ценник выше и спроса из-за этого нет, как говорят продавцы. А заказывать - ну на фиг!black910 писал(а):кажется наиболее подходящим является SynPower MXL SAE 5W-30
Есть только synpower 5w30 его и возьму.
Кстати MXL это только SL по API, а просто без MXL - уже SM, т.е. выше.
DenisR
это бензиновый допуск, надо смотреть на CF,СH. у энеоса вообще CH-4Napic писал(а): Кстати MXL это только SL по API, а просто без MXL - уже SM, т.е. выше.
sasha1971
- Двигатель:: Дизель
- Мой автомобиль(и):: NMPS 2011 2.5AT,лето - стоковая резина, зима Nordman SUV + диски Replica Mi 38 . Нагреватель-Бинар 5
вот такую информацию получил...Napic писал(а):Leshka79, нет такого масла на сайте кастрола.
Вот нарыл про оригинальные масла Митцу. Не помню откуда взял, возможно и с этой веткиА может и правда оригинальные заливать в ОД. Только вот меня почему то устраивает купить масло на стороне, привезти им (ОД) и самое главное ГЛАЗАМИ ПРОСЛЕДИТЬ, чтобы они мое купленное масло туда залили...
На таком фоне недоверия оригинальные масла блекнут...
- Вложения
- протокол испытания-1.doc
- Протокол испытаний...
- (112 КБ) 408 скачиваний
- Napic
Спасибо. Если бы я знал раньше эту информацию, то пожалуй залил бы именно оригинальное масло 5w30, но менял бы строго через 5000 км из-за щелочного числа 6 - для дизелей слишком мало.sasha1971 писал(а): вот такую информацию получил...
Стоит такое оригинальное масло, правда 0w30 390 руб литр в нашем ОД - дешевле либо не дороже аналогов. Да и искать его не надо - приехал к ОД и залил - удобно.
А так, сегодня, уже успел перейти на вэльволин синтетику, менять буду через 7500. Останусь с трансформерами навечно
А все потому, что не сказали температуру замерзания у этого масла по горячей линии Митцу....
sasha1971
Вот я и приехал что бы пошуметь,типа что вы тут льете. Хочу кастрол и все....Napic писал(а):Спасибо. Если бы я знал раньше эту информацию, то пожалуй залил бы именно оригинальное масло 5w30, но менял бы строго через 5000 км из-за щелочного числа 6 - для дизелей слишком мало.sasha1971 писал(а): вот такую информацию получил...
А так, сегодня, уже успел перейти на вэльволин синтетику, менять буду через 7500. Останусь с трансформерами навечно![]()
А все потому, что не сказали температуру замерзания у этого масла по горячей линии Митцу....Одного клиента потеряли.
- Hahalena & Maximal
Как интересно "пойдет" масло Mitsu 5w30 после 100 тысяч на мобил 0w40? По-моему стрёмный эксперимент, нет?
Новое масло Рольф (mr. Big Price) продает по 300 рублей? не дешево ли? а где его делают?
Mitsubishi New Pajero Sport, 4m41 163/369, МКПП, Т54
Зима - Blizzak dm-v2 R17
Лето - Bridgestone 684II R17 + тульские цепные изделия
- Свят
с бОльшим пробегом масло чуть гущё должно понравиться моторчику нежели жиже...
ФАНТОМ
Toyota Tundra
ФАНТОМ
Toyota Tundra
Это я усвоил. Я про смену производителей. Разные технологии и присадки. Слышал о вреде смены производителя м.масла при большом пробеге. Так ли это*?Свят писал(а):с бОльшим пробегом масло чуть гущё должно понравиться моторчику нежели жиже...
- olegro
- Двигатель:: 4М41 200лс
Получается, что придется промыть двигатель тем маслом на котором в дальнейшем собираешься ездить.Hahalena & Maximal писал(а): Я про смену производителей. Разные технологии и присадки. Слышал о вреде смены производителя м.масла при большом пробеге. Так ли это*?
- Свят
Промывка *по системе olegro*
как вариант, но мне кажется что переход на другое масло другого производителя не может быть вредным для мотора. Микс из остатков старого и нового(качественного) масла ну неможет быть отравой для мотора.
Любые доп-присадки, расчитанные для масла ДВС не имеют ведь ограничений по производителям
да и по вязкости тож...
ФАНТОМ
Toyota Tundra
ФАНТОМ
Toyota Tundra
- olegro
не претендую на авторство этой "системы"Свят писал(а):Промывка *по системе olegro* тож...
- Napic
Я так собираюсь сделать. Но с улучшениями. Т.е. заливаем масло нового производителя ничего предварительно не промывая и меняем масло после 2000 км пробега. Думаю что это самый лучший способ промывки.
- Семнадцатый
Господа. Еще раз можно.
1) Какое масло надо лить в моста на моём. И сколько? 75w90 GL5?
2) Какое масло надо лить в раздатку на моём. И сколько? 75w90 GL4?
3) Какое масло надо лить в АКПП на моём. И сколько?
