Wiring or Fuse
Добавлено: 10 ноя 2003, 15:49
inacin
I wonder if anyone can help me. I have a SWB Pajero 3.0 “L” reg. The instruments on my dash board stopped working though the lights comes on. The petrol, oil and water gauge do not work together with the speedometer and clock. My mechanic is having a hard time trying to rewire it without a wiring map. Could this be a fuse problem.Any advice or suggestions
Добавлено: 10 ноя 2003, 16:26
Monterorider
Did he check the fuses :?: :D
wiring or fuse
Добавлено: 10 ноя 2003, 17:06
inacin
he did check the fuse but they keep blowing up everytime he replaces them. He opened the dash board and some wires seem to be loose. Unfortunately Mitusbishi in London does not provide alot of customer help.
Добавлено: 10 ноя 2003, 20:26
Monterorider
I see you already posted this question on POCUK forum. I was going to suggest that. So really need wiring diagram. Don't you. What year is your Pajero?
wiring or fuse
Добавлено: 11 ноя 2003, 12:37
inacin
My Pajero is 1994. It was imported from Japan and all the instructions in the car are in Japanese to make things even harder. I purchased it in late 2001, installed a new radio and alarm system and five months after that the whole dash board stopped working.
